mzimmerer
While I see there's tools to migrate from Compact to SQL, are there any resources for doing the opposite? Coming into an existing deployment without the need for SQL, only 1gig db.
Unfortunately, you can't go from SQL server to compact, at least not with our tools. I've never tried it but you can try doing it with a 3rd party tool. But I have no idea if it will work
Thanks Charles,
I'm giving this a shot using
https://github.com/ErikEJ/SqlCeToolbox
I'll report back in case anyone else stumbles down this path.
mzimmerer wrote:
Thanks Charles,
Incase anyone else hits this.. I was unable to complete this due to error. We're looking at rebuilding the installation from scratch as a last resort.
We found no way to migrate the lansweeper DB to SQL compact or to azure SQL, pretty well stuck on SQL once that trigger is pulled.
