techieanalyst
I noticed that Exchange and Lync licenses are not being picked up
also is there any possible way to just run a report that tells me what licenses are on what machines etc?
A list of scanned product keys (and product IDs) can be found in the Lansweeper web console under Configuration\License Compliance\Product Keys.
- If the product keys you are after are included in this list, please ensure that your computers have recently been (successfully) scanned in order to detect these keys. The “last seen” dates listed for your computers should be recent. Product keys can be found on computer webpages under “Software”. You can also use the built-in report “License: Software licensekey overview”, found under Dashboard\Reports\All Reports, to retrieve a list of scanned product keys.
- If the product keys you are after are not included in this list, you can submit additional registry locations for scanning in the Lansweeper web console under Configuration\License Compliance\Product Keys. We have not been able to track down product key locations beyond what is listed in the web console however.
You can manually add license keys to the database as well, as part of license tracking. License tracking is configured under Configuration\License Compliance\License Tracking. You can create a license item (a collection of software packages), link orders to it and manually submit license keys as part of these orders.
28 REPLIES 28
techieanalyst wrote:
Not seeing xen listed?
Our report lists assets whose asset type is "Xen Server". Please verify what your assets' asset types are.
What about a report that just shows the following
VMware host cores aren't scanned. For the rest of the information you are after, try the sample (VMware) report below. (Please don't submit duplicate posts. We reply to each thread as quickly as possible.)
Select Distinct Top 1000000 tsysAssetTypes.AssetTypeIcon10 As icon,
tblAssets.AssetID,
tsysAssetTypes.AssetTypename As Type,
tblAssets.IPAddress,
tblAssets.NrProcessors,
tblAssets.Firstseen,
tblAssets.Lastseen,
tblAssets1.AssetName As GuestName,
tblAssets1.Domain As GuestDomain,
tsysAssetTypes1.AssetTypename As GuestType,
tblAssets1.IPAddress As GuestIP,
tblAssets1.NrProcessors As GuestNrProcessors,
tblProcessor.NumberOfCores As GuestCoresPerProcessor,
tblSerialnumber.Product,
Count(tblSerialnumber.SerialID) As KeyCount
From tblAssets
Inner Join tblVmwareGuest On tblAssets.AssetID = tblVmwareGuest.AssetID
Inner Join tblVmwareGuestNetwork On tblVmwareGuest.GuestID =
tblVmwareGuestNetwork.GuestID
Inner Join tblAssetMacAddress On tblAssetMacAddress.Mac =
tblVmwareGuestNetwork.MacAddress
Inner Join tblAssets tblAssets1 On tblAssets1.AssetID =
tblAssetMacAddress.AssetID
Left Join tblSerialnumber On tblAssets1.AssetID = tblSerialnumber.AssetID
Inner Join tsysAssetTypes tsysAssetTypes1 On tsysAssetTypes1.AssetType =
tblAssets1.Assettype
Left Join tblProcessor On tblAssets1.AssetID = tblProcessor.AssetID
Group By tsysAssetTypes.AssetTypeIcon10,
tblAssets.AssetID,
tsysAssetTypes.AssetTypename,
tblAssets.Lastseen,
tblAssets1.AssetName,
tblAssets1.Domain,
tsysAssetTypes1.AssetTypename,
tblAssets1.IPAddress,
tblAssets1.NrProcessors,
tblProcessor.NumberOfCores,
Order By tblAssets.AssetName,
GuestName,
- We do not currently have a release date for Lansweeper 5.1, but we hope to release a beta installer by the end of September.
- There is no "publisher" field for product keys. You would have to manually filter the product names to only report on Microsoft products.
- SQL Server: only searches for SQL Server 2005 and SQL Server 8.0 product keys are built-in. A list of supported keys can be found under Configuration/License Compliance/Product Keys. You can add registry locations to this list as well.
- A sample report that lists Xen, VMware and Hyper-V servers can be seen below.
tblAssets.Lastseen,
tblAssets.Lasttried
From tblAssets
Where ((tsysAssetTypes.AssetTypename = 'xen server' Or
tsysAssetTypes.AssetTypename = 'vmware server') And tblAssetCustom.State =
1) Or
(tblAssets.AssetID In (Select tblHyperVGuest.AssetID
From tblHyperVGuest) And tsysAssetTypes.AssetTypename = 'windows' And
tblAssetCustom.State = 1)
techieanalyst
Mind giving me a query that just looks for the hosts?
Anything that's Xen Server, VMware or Hyper-V? Not one that lists the VMs under each?
techieanalyst
When is 5.1 due?
Also how do I make it so licenses from other companies show up, only interested in MS Products?
SQL licenses don't seem to appear either, but it can detect the different versions under the SQL Server report
What I would like is a report that shows all the MS Licenses including SQL etc
techieanalyst
Is there a way I can manually assocate a VM with a Host for the xen side? Seems like it would be possible, maybe a customer query or a table edit?
Not currently, no. This feature will be included in Lansweeper 5.1. Note that we do not support making custom database changes, as these changes will be overwritten and/or cause problems during upgrades.
A sample VMware report (with counts) can be seen below. We still don't see why you would include product key counts however. Your counts will always be 1, unless a VMware guest has multiple keys of the same product. (Why would it?)
Select Top 1000000 tsysAssetTypes.AssetTypeIcon10 As icon,
tblAssets.AssetID,
tblAssets.Lastseen,
From tblAssets
tblAssets.AssetID,
tblAssets.Lastseen,
tblAssets1.Domain,
GuestName,
For Hyper-V, we recommend using a separate report (below), as Hyper-V data is stored in different database tables.
tblAssets.AssetID,
tblAssets.Lastseen,
From tblAssets
Inner Join tblHyperVGuest On tblAssets.AssetID = tblHyperVGuest.AssetID
Inner Join TblHyperVGuestNetwork On tblHyperVGuest.hypervguestID =
TblHyperVGuestNetwork.HyperVGuestID
TblHyperVGuestNetwork.MacAddress
tblAssets.AssetID,
tblAssets.Lastseen,
tblAssets1.Domain,
GuestName,
techieanalyst
The report is showing me the actual keys, not the desired result
I just want a report that shows
Host - VM Name - License Count
Example
Host A
- VM Test
- MS Office 1
- Microsoft Windows Datacenter 1
Thats the report i need
It also needs to include hyper-v servers
If there are no report results, none of your ESX(i) servers have been scanned. To scan a VMware host, do the following:
• Create a VMware credential under Configuration/Scanning Setup/Scanning Credentials by hitting the Add New Credential button.
• Submit the machine for IP Address Range Scanning, in the Configuration/Scanning Setup/Scanning Methods section of the Lansweeper web console.
• Map the machine’s VMware credential to its IP range, by hitting the green + button next to the range.
• Hit the Scan All Enabled IP Ranges Now button in the IP Address Range Scanning section of Configuration/Scanning Setup/Scanning Methods to initiate an immediate scan.
Note that we provided you with a product key report, NOT a software report. Software scanning recreates Add/Remove Programs on your machines; product key scanning checks your client machines' registries for product keys.
techieanalyst
Im hosting VMs for people and I need to keep an accurate audit of what MS software is installed, so yes its 1 but they may installed another MS Product which would cause us to fail an Audit, so I keep an audit trial of whats on each host to save my butt.
The query came back empty 😞
