zurcv
I would like to monitor a process for a specific system, its name is CProc.exe * 32, I tried to find something but I couldn't find it.
CyberCitizen
Honored Sweeper
Lansweeper doesn't do real time monitoring as such, it wasn't designed for monitor processes. When it does an inventory scan it writes the details to a database which is what is supplied, you could create a deployment report that checks if the process is running etc, but it depends on what you are trying to acomplish.
