Yas_n
Is there a program such as cisco packet tracert for network mapping(like pc's connection switch connection router etc.. on a map ) on Lansweeper?
Yas_n
I mean like Which pc connect which switch or firewall or local bone schema and so on..(like that https://goo.gl/images/AuVXwi )
Nick_VDB
Lansweeper does currently not have a feature where a map is automatically generated which will show the connections in your network between the different assets that you have scanned. This is however a feature that is on our wish list but there is no estimated release date when this feature may be released.
Currently Lansweeper provides location maps which are maps where you import a blueprint and add assets. This allows you to know in which building/rooms the different assets are located. You can find more information on how to place assets on a map in this knowledge base article.
