CyberCitizen wrote:
Have you deployed the ProPlus installer or are you using the pre-loaded Windows store versions?
With our deployments, we remove the store version and use the actual installer as I believe Lansweeper has trouble picking up / detecting store versions of apps.
I used the deployment tool to deploy the software, not the windows store. Same image org wide (we smallish)
https://docs.microsoft.com/en-us/deployoffice/overview-of-the-office-2016-deployment-tool
