Zoran
I noticed since I updated LS with the latest version 11.1.9.1, Performance Scanning is throwing errors for every machine setup, issue message is 'Issue. CheckWMIAccessEventLogOnly - DNS redirected to '''' but expected computer CompName (EventlogOnly) CompName (IPaddress) \root\cimv2'
Ver.11.1.7.1 didn't have this issue, so this might be a bug in the new version?
Thanks in advance
12 REPLIES 12
mmwend
After updating onprem Lansweeper to version 11.1.10.5,
the Performance Scanning is now working again.
It looks like it will have to "re-populate" itself, but it is working again.
Michaelzip0
I see the latest update states there is a fix patched in ill try updating.
Michaelzip0
also having this issue and im at 11.1.9.1
Zoran
Just to pass the news, LS confirmed this is a bug introduced in version 11.1.8.1 and their development team is working on a fix. I believe this will be resolved in the next version.
Thank you LS
Mercedes_O
Community Manager
Community Manager
Thank you for the update Zoran, we appreciate your patience while our teams look into this matter
mmwend
I just noticed the Scan issues too:
CheckWMIAccessEventLogOnly - DNS redirected to '''' but expected computer QCxxxx (EventlogOnly) QCxxxx (10.0.x.x) \root\cimv2
This is mainly on my Windows servers where I have "Performance"  (CPU, Memory, Disks, network) enabled for 30 minutes. My one (1) Windows 10 workstation that I have Performance enabled seems to be fine with no scan issues. I don't know what triggers the Scan issues.
All scan times seem normal. Nothing is high as everything there is as expected.
I am running Lansweeper (On-Prem) v 11.1.9.1
Mister_Nobody
Honored Sweeper II
You have to create support case.
We did also, but no really information about an known problem, so i am glad to see, that we are not alone 🙂
tenupmoc
Hi, we have excactly the same problem!
Have you also high scanning times für item scan like software, serialnumber etc?
