BSysAdmin
Hi All,
I have created a custom role for a group of users who should only be able to see assets and generate/view reports. They should not have access to the configuration.
I have given them the following permissions, but they are still able to access the configuration.
How do I restrict access to configurations?
DavidPK
We are unable to reproduce your issue in our internal testing. Using the same permissions you have selected it works as expected. Make sure you are on the latest version. Normally Lansweeper follow the least privilege however ensure that this users don't belong to any other groups.
Obi_1_Cinobi
Hello there!
If this issue is still occurring, and you need further technical assistance, please raise a support case: https://www.lansweeper.com/contact/contact-support/
If you need technical support and have issues with accessing the Support Portal, please use this URL instead: https://www.lansweeper.com/contact/contact-support-case/
