Flatl3y
I've followed the user guide to create a power bi dashboard - Create a Lansweeper Power BI Dashboard Template - Lansweeper Community - 78904 but it isn't pulling any vulnerability information or any of the information from risk insights - is this possible?
EthanB
The integration out of the box is not designed to pull the vulnerability information which is why you are not seeing it. This would require some configuration in the backend to add the vulnerability information. You would need to edit the query in the advanced editor to get different fields. The field I would recommend adding would be vulnerabilities.cve to see the CVEs in your environment. A full list of fields that you can pull via the API can be found here: Types specification | Documentation – Lansweeper.
EthanB
