Options
‎01-09-2021 05:52 PM
Goodmorning
In my company we are using Lansweeper.
I need to to automate some tasks basing on the Lansweeper assets.
At its basics, I need to query and filter lansweeper assets and perform some tasks on each filtered asset.
Is there any supported way to integrate Lansweeeper into automation?
I use powershell.
I have found a module on the Powershell Gallery: https://www.powershellgallery.com/packages/Lansweeper-PS/1.30.5
However, I cannot get it to work.
Could you please help me with this module?
How should be the get-LSasset command to get all the Assets object with all the properties
What I know is:
- Lansweeper server Ip address (and name)
- My username and password (I sucessfylly login and query assets on the web pages)
If you have different solution (python, .Net... whatever) please tell me.
Thank you for your kind help
I use powershell.
What I know is:
Labels:
General Discussion
6 REPLIES 6
Options
‎05-23-2022 08:15 PM
I've been able to query lansweeper from powershell and have integrated it into several scripts. I use a couple components to make this work.
the
The way I use this is to call the function and assign the results to a $var. That $var is a ReallySimpleDatabase in-memory db. I then query that to pull the results. You could easily change the way it is used.
the
get-sqlmodule allows me make queries and the ReallySimpleDatabase allow me to move the results into an in-memory database for further queries. Here is some sample code
function Build-LSInfo {
#Grabs all assets in lansweeper with usernames defined
#stored in sqlite db
$sql = @"
Convert(nvarchar(10),Ceiling(Floor(Convert(integer,tblAssets.Uptime) / 3600 /
24))) + ' days ' +
Convert(nvarchar(10),Ceiling(Floor(Convert(integer,tblAssets.Uptime) / 3600 %
24))) + ' hours ' +
Convert(nvarchar(10),Ceiling(Floor(Convert(integer,tblAssets.Uptime) % 3600 /
60))) + ' minutes' As UptimeSinceLastReboot,
tblAssets.Lastseen,
tblAssets.Username,
tblAssets.IPAddress,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
Coalesce(tsysOS.OSname, tblLinuxSystem.OSRelease, tblMacOSInfo.SystemVersion)
As OS
From tblAssets
Left Join tsysOS On tsysOS.OScode = tblAssets.OScode
Inner Join tsysIPLocations On tsysIPLocations.LocationID = tblAssets.LocationID
Left Join tblLinuxSystem On tblAssets.AssetID = tblLinuxSystem.AssetID
Left Join tblMacOSInfo On tblAssets.AssetID = tblMacOSInfo.AssetID
Where (tblAssets.Lastseen > GetDate() - 30 And tblAssets.Domain = 'OURDOMAIN'
And tblAssets.Lasttried > GetDate() - 45) Or
(tblAssets.Uptime Is Not Null And tblAssets.Domain = 'OTHERDOMAIN' And
tblState.Statename = 'Active')
Order By tblAssets.Uptime Desc,
tblAssets.IPNumeric
$db_x = $null
$db_x = get-database #creates an in-memory db using ReallySimpleDatabase (see docs for using an on-disk db)
#queries the lansweeper db defined in the connection string; session stored in "TT"
$hld = get-sql -MsSQLserver -connection "Server=lansweeper.myco.com;Integrated Security=true;Initial Catalog=lansweeperdb;ApplicationIntent=ReadOnly" -Session TT
#Sends the results of the query to the sqllite db using import-db - creates LSU table
TT $SQL |import-database -database $db_x -tablename LSU
#$db_x = TT $SQL
#closes the session TT
TT -close
#returns the in-memory db
return $db_x
Options
‎01-23-2022 10:48 PM
Goodevenig
One year is passed since my original question about the availability of a powershell module for Lansweeper.
I still have the same need but one of the first links out of my google search are about this post.
As far as you know, has Lansweeper development team created a module for powershell?
Is there an API, or the web interface is the only way we can access lansweeper?
Thank you for your help
Options
‎01-26-2021 01:48 PM
We are using a similar approach in our environment to test the VNC connection to a dynamic list of Workstations using PowerShell.
How we do it is like this:
1. Daily export the list (based on a custom filter) of Workstations to a csv file
2. Scheduled Posh script imports the csv, executes a command to test the VNC port and sends the result to a mail recipient.
Importing the csv is done by this command:
import-csv -delimiter ';' -path "C:\Program Files (x86)\Lansweeper\Service\export\VNC-check.csv"
Testing the port is done by this command:
new-object System.Net.Sockets.TcpClient($rh, $p)
Options
‎01-20-2021 12:34 PM
SubnetJO wrote:
Goodmorning
I don't know if I understood your problem
You could use "deploy package" in Lansweeper web console: create a deploy package with the configuration you need and then a report filtering the right assets
in the report's asset list you can deploy the package to the assets
let me know, regards
Options
‎01-24-2021 07:18 PM
ufficioced wrote:SubnetJO wrote:
Goodmorning
Thank you for your kind answer
However, what I need is to query lansweeper programmatically, hopefully integrating with a powershell.
Let's say I want to know how many IP Locations with a name that starts with "XYZ" I have, and then doing something elsewhere basing on the result.
For example I have a list of licenses assigned to each IP Location.
I need to check if we have licenses still assigned to no longer existing sites.
So I need to compare the list of the licenses and the list of the alive sites.
Where I can get the list of the alive sites?
I'm told "look at the IP locations in lanswepeer".
So, since my scripts are powershell, my question is: how can I query Lansweeper by powershell?
I know of the "unofficial" module, I tried it, but I cannot get it to work.
Is there something Official?
Is there any programmatical way to query Lansweeper, without querying the undergoing database directly, of course
Options
‎01-26-2021 08:24 AM
You need an API but as far as I know is under deployment in Lansweeper.
I think you can use a different approach with reports (exporting for example in Excel) and deployments, but I don't really know your configuration so I can't assure you this is the right way.
