earellano
Since I have updated Lansweeper to the latest version, I am having problems with the Licenses section, within the software, they have multiplied and it no longer works well, I attach the current image and another one of how it appeared before the last update, to see if they can give me a solution, thank you.
earellano
Perfect,
I'm sending the GatherLogs file and the screenshots right now,
thank you very much.
ErikT
Hello there!
Our tech support team should be able to assist you with this.
How to contact support?
Using the GatherLogs tool.
