paprita
I've upgrade SQL from 2000 to 2005 version using backup/restore procedure.
Then I've reinstalled lansweeperservice on a server and web site on another server (I've tryed both 3.5.1 and 3.5.2 beta versions).
Now situation is:
- db seems to run correctly;
- lsmanage.exe run correctly (I can see the db);
- lansweeperservice.exe can't start due to login error (Cannot connect to database, check your config file, service will be stopped Cannot open database "lansweeperdb" requested by the login. The login failed.
Login failed for user 'lansweeperuser'.)
- web site doesn't work due to login problem too as follow:
System.Data.SqlClient.SqlException: Cannot open database "lansweeperdb" requested by the login. The login failed.
What's the problem?
In attach web.config and Lansweeperservice.exe.config
paprita
After all we found a way to solve this problem:
- delete lansweeper schema (databases\lansweeperdb\security\schemas)
- delete lansweeperuser (databases\lansweeperdb\security\users)
- delete lansweeperuser (security\logins)
- create lansweeperuser (security\logins)
- create lansweeperuser (databases\lansweeperdb\security\users)
- create lansweeper schema (databases\lansweeperdb\security\schemas)
Now it seems to go properly but I'm not sure to see any improvement passing from SQL 2000 to 2005 ...
21 REPLIES 21
Check if your Data source is correct.
Check the database name (lansweeperdb) (should be the same)
Check if user lansweeperuser exists and if it has access to the lansweeperdb
If not create the sql user and make him dbowner.
Data Source=Serv-ISRO-TEST;
Initial Catalog=lansweeperdb;
User ID=lansweeperuser;
Password=mysecretpassword0*
paprita
Yes.
Yes.
Yes.
What else?
