benet
A customer said to me that users AD status in not updated for users passed from enabled to disabled in their on-prem AD.
One of your article explain how to scan disabled users account : https://www.lansweeper.com/knowledgebase/disabledactivedirectory/
But in fact I cannot find out "Scan Users that are disabled in on-premises Active Directory" option to check if it's activated or not...
We are in version : 10.1.1.0
7 REPLIES 7
David_GF
We've tested it in our environment and are able to reproduce it on several machines, so it is indeed a bug. We have filed a bug with our developers, When a fix is available, it will be listed as LAN-14170 on our changelog:  https://www.lansweeper.com/changelog/
Sweep that LAN, sweep it!
DonMario73
Greetings, can you confirm the status of this bug?
Thks!
David_GF
@DonMario73 @Mister_Nobody That bug was fixed via a previous bug, it was released in v10.3 https://www.lansweeper.com/product/changelog/?search=LAN-13747
KevinA-REJIS
I tested it on our scanserver and I'm seeing the same as you are - leaving the page and coming back unticks the box again. I would recommend sending this to Lansweeper support.
KevinA-REJIS
It's found under Configuration -> Server options
Edit: Turns out that's just for removing users from Lansweeper that are disabled or deleted in on-premise AD. I don't know if there's a scan option anymore.
Edit 2: I found it, on the Scanning Targets under Scanning Scope.
Thanks Kevin four you feedback !
Finally I found out as you options... BUT... For the one under "Scanning Targets under Scanning Scope" when I tick it, go back to another page, and come back again, the tick is gone....
Any idea ?
