nieboerb
Hello
We are in a mixed environment client with and without LsAgent since some users not in the office and are Cloud only laptops.
But still we get scanning errors when the user is in the office.
This asset is excluded from agentless scanning (LsAgent only).
How can we disable RPC  and Ping for laptops using LsAgent? The message says:
Thanks.
FrankSc
Dear,
LsAgent is running locally and will not generate RPC or ping errors.
If you keep seeing the errors, it means that the assets are still being targeted with an agentless scanning target.
It seems that the asset is marked to be scanned with LsAgent only, but there is a apparently still an ongoing agentless scan.
Please check your scanning targets anyway and for example also the performance scanning targets.
FrankSc
Dear,
