RagnarDylan
can somebody please help with a scanning issue that is occurring for me
I work in an enterprise and we have multiple domains I've had no issue scanning additional domain's but this particular domain I am having trouble with
doesn't seem to work no matter which credentials I use I'm certain I'm using the correct password's also
using the test connection on one one of the machines displays the following
remote computer - NACSH1MC8P2
Status: Running
Version: 6.0.150.60
Pinging NACSH1MC8P2
Ping failed.
Scanning TCP ports..
135 closed (EPMAP)
139 closed (NetBIOS Session Service)
445 closed (SMB)
Checking DNS..
Could not resolve the DNS name, please check for DNS problems.
No such host is known
Scanning WMI..
The RPC server is unavailable.
Checking C$ Access
Connection Failure. Error: The network path was not found
Checking Task Scheduler
Done.
Remote computer 10.75.129.107
Lansweeper Connection Tester 6.0.150.3
Status: Running
Version: 6.0.150.60
Pinging 10.75.129.107
Ping ok.
135 open (EPMAP)
139 open (NetBIOS Session Service)
445 open (SMB)
Checking DNS..
10.75.129.107 resolved to: 10.75.129.107
If this is not correct, please check for DNS problems.
Checking reverse DNS..
10.75.129.107:
Could not resolve the reverse DNS, please check for DNS problems.
Scanning netbios (UDP)..
Computername: NACSH1DB8P2
Domain: GPL84047
Scanning netbios (445)..
Domain: GPL84047
Scanning Active Directory..
Error: The specified domain does not exist or cannot be contacted.
Domain: GPL84047
Scanning WMI..
Access is denied, please check your credentials.
Checking C$ Access
Connection Failure. Error: The specified network password is not correct
Could not edit Registry to scan Kerberos errors
Done.
JacobH
with multiple domains... do you have the other domain in the DNS Suffix search order/list for whatever network the lansweeper scanning server is on?
to test, put NACSH1MC8P2.whateveritis.local (The FQDN) in the tester .EXE
Pinging NACSH1MC8P2
Ping failed.
135 closed (EPMAP)
445 closed (SMB)
I'm not sure why this asset is not responding to a ping, but that would be step 1 to figuring this out. From what I can see here, the machine is simply offline or doesn't exist.
Status: Running
Version: 6.0.150.60
Ping ok.
135 open (EPMAP)
445 open (SMB)
Checking DNS..
10.75.129.107:
Domain: GPL84047
Domain: GPL84047
Domain: GPL84047
Scanning WMI..
If the credentials used here have local administrative rights, then the issue is most likely WMI ports not being open.
You can find some documentation to setup the assets for scanning here:
Ports Used by LS: https://www.lansweeper.com/knowledgebase/used-tcp-ports/
Configure firewall: https://www.lansweeper.com/knowledgebase/firewall/
If you can't figure it out, it's best you contact our support team with the same information so they can take a closer look.
