‎03-29-2022 04:59 PM
Solved! Go to Solution.
‎03-31-2022 01:20 PM
‎04-01-2022 02:28 PM
Bruce.B wrote:
We're investigating reports that querying Win32_SystemDrivers can cause a performance impact on the scanning server and the scanned system in some circumstances. If you're experiencing a performance issue on your Lansweeper server, try doing the following:
- Go to Scanning\Scanned Item Interval
- Disable the SYSTEMDRIVERS item
- Clear the scanning queue via Scanning\Scanning Queue
- Restart the Lansweeper Server service to sever any ongoing connections
In regards to LsAgent relay connections, there is no known issue with the relay server. Keep in mind that the scanning service checks into the relay to pull assets every hour. If you're seeing an error every hour you may indeed have a connection issue in which case I recommend checking out this article. If you're only seeing error intermittently, this isn't a cause for concern.
‎03-31-2022 03:14 PM
‎03-30-2022 03:31 PM
‎03-31-2022 12:08 AM
Notonyourradar wrote:
Same with the CPU / Memory. Is anyone also having issues with Cloud relay agents reporting in?
‎03-30-2022 01:59 PM
‎03-29-2022 11:13 PM
JFK wrote:
Anybody else gets some issue with new version 9.3.10.7 ?
Scanning not work anymore, computer stay stuck in the Windows computer scanning.
CPU always nears 80-90 % and Memory to 10 Gb.
Database has been optimized from 19 Gb to 4.4 Gb after reducing event log retention.
We have a lot of "1 scanning takes longer than 1 hour, repair wmi on this machine!" but all this machine was OK before.
Any else ?
‎03-29-2022 09:19 PM
‎03-29-2022 09:25 PM
abetzold wrote:
I have been having issues and finally found the bug in the error logs. Yes it has to do with driver scanning:
SqlException Errors:
-> Number 242: The conversion of a datetime2 data type to a datetime data type resulted in an out-of-range value.
Following properties may have cause the implications:
- Property: "DriverDate", Type: Nullable<DateTime>, Value: "01/01/1601 00:00:00"
- Property: "LastChanged", Type: DateTime, Value: "01/01/0001 00:00:00"
---> System.Data.Entity.Infrastructure.DbUpdateException: An error occurred while updating the entries. See the inner exception for details. ---> System.Data.Entity.Core.UpdateException: An error occurred while updating the entries. See the inner exception for details. ---> System.Data.SqlClient.SqlException: The conversion of a datetime2 data type to a datetime data type resulted in an out-of-range value.
The statement has been terminated.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.Entity.Infrastructure.Interception.InternalDispatcher`1.Dispatch[TTarget,TInterceptionContext,TResult](TTarget target, Func`3 operation, TInterceptionContext interceptionContext, Action`3 executing, Action`3 executed)
at System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.Reader(DbCommand command, DbCommandInterceptionContext interceptionContext)
at System.Data.Entity.Core.Mapping.Update.Internal.DynamicUpdateCommand.Execute(Dictionary`2 identifierValues, List`1 generatedValues)
at System.Data.Entity.Core.Mapping.Update.Internal.UpdateTranslator.Update()
--- End of inner exception stack trace ---
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction(Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectContext.SaveChangesToStore(SaveOptions options, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction)
at System.Data.Entity.SqlServer.DefaultSqlExecutionStrategy.Execute[TResult](Func`1 operation)
at System.Data.Entity.Core.Objects.ObjectContext.SaveChangesInternal(SaveOptions options, Boolean executeInExistingTransaction)
at System.Data.Entity.Internal.InternalContext.SaveChanges()
at Lansweeper.EF.Toolkit.DbContextBase`1.SaveChanges()
at Lansweeper.EF.Toolkit.GenericRepository`1.AddRange(IEnumerable`1 entity, IDbContext context)
at Lansweeper.Service.BL.DriverScanning.DriverScanningManager.SavePrinterDrivers(IList`1 printerDrivers, IDbContext dbContext)
2022-03-24 08:28:27,118 [43] ERROR SavePrinterDrivers: Error occurred saving printer drivers.
System.Data.Entity.Infrastructure.DbUpdateException: Entity of type "PrinterDriver" in state "Added" has caused a DbUpdateException.
So I have a printer driver out there and the developer didn't put a date in so 1601 is returned and is crashing during the table update for every device with this driver.
