PL-Infra
I've got two sets of assets with strange behavior. These are two physical Hyper-V Servers:
  • server1 - 192.168.100.100
  • server2 - 192.168.100.102
Each with an HPE iLO asset:
  • server1ilo - 192.168.100.101
  • server2ilo - 192.168.100.103
Server1 and server2 both run different OS and the version of iLO 2 is 2.33 03/20/2018
Everytime the iLO asset gets scanned, the corresponding server asset changes its IP to the IP of the ilo asset. So server1 will get 192.168.100.101 as IP. As a consequence the asset server1 will get a status of "RPC Server unavailable". Only by changing the IP of server1 I can resolve this (temporary)
How can this be resolved permanently?
PL-Infra
Did some additional research on the iLO host using Lansweeper Device Tester (Thanks!):
Scanning SNMP..
ObjectID: 1.3.6.1.4.1.311.1.1.3.1.2
Scanning SNMP for custom OID's..
Valid connection: True
OID 1.3.6.1.2.1.1.5.0: server1
So this specific setting was causing for issues:
Administration/Settings/Management/
SNMP Pass-thru: Enabled Disabled
When this was changed to Disabled:
Scanning SNMP..
Stopped: No SysObjectId found
Now, there are no references to server1 when scanning server1ilo
