itsaleri
Hi to all,
I'm experiencing a problem related to the SSO feature of Lansweeper.
I'd like to login in the lansweeper webconsole by ONLY opening the web browser without inserting username and password (pure SSO).
Is it possible? Our environment is a Microsoft Domain.
Regards
duster1
You are certainly able to do this!
See the documentation here: Enabling IIS Express authentication Customizing the Web Console - (lansweeper.com)
Prior to doing the above, make sure you lock down your system : Restrict access to the web console Customizing the Web Console - (lansweeper.com)
hubertmroz
patriotxt
I believe you can achieve this by forcing the SSO only in the console. Check your SSO settings in Lansweeper, the option should be there. Caution, read the documentation!
