Patrick Allers wrote:
I have an extending question to this specific topic:
In case I've done it like here but gave the Agent option to either choose Yes / No when closing the ticket. Is it possible to open up a way to input the time worked at the ticket in the "Closing" Screen when pressing "No" just like you can do on each answer to a ticket?
Kind regards,
Patrick
You probably could set up a custom field, but that wouldn't calculate the total time for reporting, unless you used that custom field in a custom report.
That's a good idea though, I think I'll try that.
