Options
‎03-07-2017 10:53 AM
There are any way to do time worked on a ticket as a required field when close the ticket?
Thanks in advance
Josep
Thanks in advance
Josep
Solved! Go to Solution.
Labels:
General Discussion
Options
‎03-07-2017 01:57 PM
You can't set the time worked feature as a mandatory fill field for closing directly, but you could work around this:
This will have the effect that your agents need to check this box every time they close a ticket of this type, which will remind them to input work time.
- Create a new Yes/No Ticket Custom Field under Configuration\Ticket Content, as seen in the example screenshot below
- Add this to the ticket types where you would like to see time worked being tracked. Under Configuration\Ticket Content you can click the Alter Custom Fields button to add this newly created custom field to individual ticket types, make it agent only and required for closing
Options
‎10-23-2019 10:57 AM
I have an extending question to this specific topic:
In case I've done it like here but gave the Agent option to either choose Yes / No when closing the ticket. Is it possible to open up a way to input the time worked at the ticket in the "Closing" Screen when pressing "No" just like you can do on each answer to a ticket?
Kind regards,
Patrick
Kind regards,
Patrick
Options
‎02-27-2020 01:04 PM
Patrick Allers wrote:
Kind regards,
Patrick
You probably could set up a custom field, but that wouldn't calculate the total time for reporting, unless you used that custom field in a custom report.
That's a good idea though, I think I'll try that.
Options
‎03-07-2017 02:20 PM
Thanks!
I'll do it.
I'll do it.
Options
