Erwin
Not sure if this is the right way to go, but within the KB article vCenter scanning requirements - Lansweeper Community there is something missing. If I exactly follow the steps within the article I am able to login to the vCenter, but not able to see Datacenter, Cluster, Hosts, VM's. This is caused because inside the article within step 8, the option Propogate to children option is not mentioned. See screenshot.
Can this be changed?
Thank you
Erwin
Obi_1_Cinobi
Hello there!
We have passed this information on to our technical writers so they can look into this! Thank you for reporting it!
