‎07-13-2017 01:52 PM - last edited on ‎01-12-2023 07:10 PM by Mercedes_O
I've used Lan Sweeper for a long time now and its a great asset management tool, though one of the thing it could really use is some real-time monitoring and alerting.
I'm not talking anything fancy here just having the potential to monitor a device on a choice of standard ports (perhaps 6 or 7), draw a topology map (or two) and take some action(s) on an alert.
Like I said nothing fancy and over bloated just something simple and robust.
A good example was Didyma (which can be here https://houtriet.home.xs4all.nl/Didyma/Download/ ) from my old XP days but which is unfortunately appears to be no longer maintained.
But it gave you monitoring of the following ports :
Anyone else agree?
Dog.
‎04-09-2019 08:37 PM
‎04-10-2019 08:13 AM
AZHockeyNut wrote:
real time would be nice but even a map that can be created from the data switches return of what is connected to them in come kind of widget would be nice.
‎07-19-2017 01:20 PM
I think that the real missing component in LanSweeper is an alerting layer, this great software is a inventory (and a lot more) tool, but it hasn't real time alerting features.
If you are not interested in a real time monitoring you can use scheduled deployment to execute some script, and collect data in some way but of course this is not so simple.
Anyway I'm very interested in this topic.
‎05-30-2023 08:49 PM
any update on this? is it just still on the wish list?
a week ago
Typical Lansweeper support - no answer at all.
it seems like you are too focussed on putting in half baked ideas like a helpdesk into the software. you are 10 years of development away from creating a half usable helpdesk module, so I have no idea why you would water down your great asset management application with a completely unusable helpdesk module.
Try adding the features that your customers are actually asking for.... this request has been with you guys for over 7 years now and you havent bothered to even reply very well .....
a week ago
we gave up and got a software called pulseway for our major alerts we do use LS for historical information as in how long has this been an issue regarding things like CPU and RAM usage, it be nice if the two companies had an integration, we also still use LS for our dashboard alerts for things like low toner level or low storage alerts but they are for systems not as important that I need an email alert right away. but yes wish LS would get this added, but doubt we would get rid of pulsway if it happened due to us using it for our remote updates wich LS dose not do.
‎07-19-2017 10:49 AM
