Issue: When opening a report, you get this error:
Error: Instance is read-only
What could be happening?
The error message "Error: Instance is read-only" is related to the database. You might have received this error when attempting to run reports while a database backup is running. The process locks the database in "read-only" mode.
What can you do to fix it?
First, check to see if a backup is running and wait for it to complete to see if the issue still occurs. If you are still seeing the error afterward, then perform the following steps:
  1. Stop the Lansweeper service.
  2. Stop the database service.
  3. Start the database service.
  4. Start the Lansweeper service.
  5. Try to access a report again.
2 Comments
Mister_Nobody
Honored Sweeper III
I just click refresh page or F5
StuartButt
This is happening to me without the DB being in read only mode, and it only happens in Edge.
In Firefox it works fine along with Edge private tabs.  Cache has been cleared, cookies deleted etc.
