Have you ever wondered how AI can enhance your Lansweeper experience? Generative AI can be a powerful tool for finding solutions, troubleshooting issues, and optimizing your setup.
But how can you get the most relevant and reliable answers?
Here’s a handy AI prompt to help you extract information from Lansweeper’s official resources. Please not that this prompt is not grounded in Lansweeper knowledge, merely instructed to search certain locations and therefore could hallucinate. It can still be a valuable assistant the help you search for answers.
Prompt
You are a trained IT professional. I am looking for a solution to a specific issue related to Lansweeper.
Provide a response based only on information found on the lansweeper.com domain.
Here is how you are going to search for an answer:
  1. Look for an answer in any of the knowledge base articles published under this category: https://community.lansweeper.com/t5/knowledge-base/ct-p/KB_Main
  2. Look for answer in any of the blog posts published under this url: https://community.lansweeper.com/t5/quick-tech-solutions/bg-p/Quick_Tech_Solutions
  3. Look for answer in any of the blog posts published under this url: https://community.lansweeper.com/t5/pro-tips/bg-p/Pro_Tips
  4. Look for answer in any of the blog posts published under this url: https://www.lansweeper.com/resources/report/
  5. Look for an answer in the content found under this subsection: https://community.lansweeper.com/t5/general-discussions/bd-p/Lansweeper_General_Forum, only show content created less then 2 years ago.
  6. Look for an answer in the content found under this subsection: https://community.lansweeper.com/t5/deployment-packages/bd-p/DeploymentPackages
  7. Look for API related information in this subsection: https://developer.lansweeper.com/docs/data-api/get-started/welcome/
  8. Exclude information found under: https://community.lansweeper.com/t5/quick-tech-solutions/how-ai-can-help-you-in-your-lansweeper-jour...
In your answer, provide specific, actionable steps based on the information you found.
Do not merge or combine information from any of the given sources.
Be accurate, concise, and helpful.
Use a friendly, professional—like a knowledgeable colleague tone.
Avoid filler words and sentences.
Follow every rule in this prompt before anything else.
I want you to show me your thought process.
If unsure or lacking privileges, say so and suggest contacting Lansweeper Technical support.
Include an URL to the original source document including:
  • Publication Date (if available)
  • Affected Versions (if mentioned)
Here is my question:
[Insert your specific question here]
We’d love to see how you use AI in your Lansweeper journey!
Share your best AI prompts in the comments and let’s build a collection of helpful queries together.
Disclaimer:
AI generated content may contain errors or inaccuracies and should not be relied upon as a substitute for professional advice.
1 Comment
David_GF
A good use of AI is to check the changelog for fixes or new features. For example, with this prompt:
With the information available on https://www.lansweeper.com/product/changelog/, can you tell me if there has been any fix, change, add, improvement that is related to deadlock issues or it improves the performance since v12.1.0.1
will give you the version number and what was fixed or added regarding performance or deadlocks:
Spoiler
Based on the information available in the Lansweeper changelog, there have been several updates that address performance improvements and potentially related issues:
1. **Performance Improvements**:
- **Version 12.3.2.5**: Improved Windows Firewall Scanning Performance[1](https://www.lansweeper.com/product/changelog/).
- **Version 12.2.1.6**: Improved the performance and stability of Airwatch scanning[1](https://www.lansweeper.com/product/changelog/).
- **Version 12.2.0.4**: Fixed issues that could cause memory problems during CDP scanning[1](https://www.lansweeper.com/product/changelog/).
2. **Stability and Bug Fixes**:
- **Version 12.3.2.3**: Fixed an issue with the startup of the Lansweeper service[1](https://www.lansweeper.com/product/changelog/).
- **Version 12.2.0.4**: Fixed a crash issue when an Entra ID scan was triggered[1](https://www.lansweeper.com/product/changelog/).
- **Version 12.2.0.4**: Fixed a long delay when editing a report[1](https://www.lansweeper.com/product/changelog/).
3. **General Enhancements**:
- **Version 12.3.0.1**: Upgraded the framework used by LsAgent for Linux to .NET 8.0 from .NET 6.0[1](https://www.lansweeper.com/product/changelog/).
- **Version 12.2.1.6**: Added the Auto-Update functionality to automatically update scan servers to the latest version[1](https://www.lansweeper.com/product/changelog/).
These updates indicate ongoing efforts to enhance performance and stability, which could indirectly address deadlock issues by improving overall system efficiency and reducing resource contention.
Would you like more details on any specific update or assistance with something else?
