LsAgent scans don't generate scanning errors as the agent has the required admin rights to locally scan the machine.
If you are scanning your devices with LsAgent and see scanning issues like RPC unavailable, firewall issues, access denied, etc., these are most likely the result of agentless scans that are still targeting the concerning devices.
To resolve this issue:
  • navigate to the Scanning > LsAgent scanning page to find the LsAgent groups.
  • In the Configuration tab, you can find the "LsAgent only" option. When this option is enabled, Lansweeper will only process scanning information from LsAgent for the assets within the LsAgent group.
  • If you are using multiple LsAgent groups, remember that you must enable this option for each group individually.
