Options
‎10-28-2008 06:27 PM
I recently installed Lansweeper within my test domain, to trail it for use. The setup is as follows:
Service and website running on Windows 2003 Server, which is a domain controller.
I have SQL 2008 Express running on a separate Windows 2003 server.
When I attempt to view the Web Console, all I get is SQL errors:
Can anyone assist? Thanks.
System.Data.SqlClient.SqlException: The SELECT permission was denied on the object 'Tsysreporthomepage', database 'Lansweeper32', schema 'dbo'.
System.Data.SqlClient.SqlException: The SELECT permission was denied on the object 'web30totaldomain', database 'Lansweeper32', schema 'dbo'.
System.Data.SqlClient.SqlException: The SELECT permission was denied on the object 'web30lastscan', database 'Lansweeper32', schema 'dbo'.
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
Labels:
6 REPLIES 6
Options
‎10-28-2008 09:42 PM
Correct, same machine, same instance of SQL 2008. I am just remembering now, that I did the install a little different from what could be called the normal. I installed the service and the website, then at a later time, shortly afterwards actually, I created the database by running the installer again and only selected the to install the database. I'm ashamed to admit I didn't read the docs well enough and though that by selecting the database option the first time meant installing SQL. Once I realized my error I went in and installed the database portion. Seems like it didn't like that.
Options
‎10-28-2008 09:34 PM
Interesting, uninstalled Lansweeper, deleted the database, and removed the virtual directory from IIS. Rebooted, and reinstalled, seems to be working now.
Options
‎10-28-2008 09:38 PM
On the same database (sql 2008)?
Options
‎10-28-2008 09:11 PM
The installer hasn't been tested yet on sql express 2008.
It's probably a new security feature.
Options
‎10-28-2008 06:32 PM
No errors just the usual stuff with regards to mixed mode authentication, TCP/IP, and named pipes.
I saw another post that had info on the "web30totaldomain", but that poster did not encounter the same issues I did.
If I use the GUI console, it works, at least it doesn't give errors, but no servers are reporting, even though the lsclient.exe is pushed out via GPO, and I can confirm the GPO is working. Thanks.
Options
‎10-28-2008 06:29 PM
Did you get any errors during the installation of Lansweeper?
