‎06-04-2010 05:12 PM
It won't let me use the lstrigger tool because that requires a domain name. And since these are devices, not computers, they aren't part of AD.
-Clint
‎06-08-2010 04:18 PM
‎06-08-2010 04:10 PM
Login failed for user 'lansweeperuser'.
A severe error occurred on the current command. The results, if any, should be discarded.
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at LansweeperService.MdlServiceStatus.WriteServiceStatus()
‎06-08-2010 03:47 PM
when you go to http://127.0.0.1:9524 on the server is the queue empty?
‎06-08-2010 03:31 PM
I also added a new scan-range for our phones and clicked the button to 'scan all available ranges' and they do not seem to be showing up yet.
-CLint
‎06-07-2010 10:26 PM
‎06-07-2010 08:28 PM
Latest version is 4.0.0.27
‎06-07-2010 06:31 PM
Nothing new in the service/errorlog.txt file in the last couple of weeks.
‎06-04-2010 11:29 PM
Do you see any errors in the errorlog file?
‎06-04-2010 11:17 PM
