Sayonara_SA
Hi
When i try to start the LansweeperPRO service i get the following
The LansweeperPRO service on Local Computer started and then stopped. Some services stop automatically if they have no work to do, for example, the Performance Logs and Alerts service
What does that mean ?
25 REPLIES 25
Sayonara_SA
thanx alot
looks like everything is working like a breeze now
just one thing
I do not get the description, model,vendor, tag etc detail from the other laptops
do i need to open a port on the latops firewall for lansweeper to pick this up
if so which port 9524?
if a disable the firewall i get all the detail i need so it must be a firewall thing
can i do this via GPO?
Don't wordwrap your file, put
<add key="ConnectionString" value="Persist Security Info=False;Data Source=127.0.0.1\sqlexpress;Initial Catalog=Lansweeper;User ID=lssqluser;Password=!@lssqluser()" />
on one line without any enters
Sayonara_SA
now how do i do that ?
i don't see an option to attach a file ?
sorry ..... hectic day today ... hop the file is what you looking for.
Had to rename it didn't want to upload it
Could you attach it as a file please.
Sayonara_SA
lansweeper30 config file
<configuration>
<appSettings>
<add key="ListenPort" value="9524" />
</appSettings>
</configuration>
Could you attach your lansweeper30.exe.config file please.
Sayonara_SA
i cannot see anything if i type go to the http://127.0.0.1:9524
error log
2008/02/20 03:54:53 PM
System.ArgumentException: Keyword not supported: 'persist security
info'.
at System.Data.Common.DbConnectionOptions.ParseInternal(Hashtable parsetable, String connectionString, Boolean buildChain, Hashtable synonyms, Boolean firstKey)
at System.Data.Common.DbConnectionOptions..ctor(String connectionString, Hashtable synonyms, Boolean useOdbcRules)
at System.Data.SqlClient.SqlConnectionString..ctor(String connectionString)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnectionOptions(String connectionString, DbConnectionOptions previous)
at System.Data.ProviderBase.DbConnectionFactory.GetConnectionPoolGroup(String connectionString, DbConnectionPoolGroupOptions poolOptions, DbConnectionOptions& userConnectionOptions)
at System.Data.SqlClient.SqlConnection.ConnectionString_Set(String value)
at System.Data.SqlClient.SqlConnection.set_ConnectionString(String value)
at Lansweeper30.starter.startsweeper()
check the errorlog.txt for any errors.
check if you can surf to http://127.0.0.1:9524
Sayonara_SA
it looks like the service is running and i opened the port 9524 on the firewall but if i do a netstat -a i cannot see the port
any other way to force the port open ?
I tink that the problem was that your config file started with an empty line
