Lansweeper wrote:
Open the web.config and set debug=false to "true"
Open the file state.aspx and set debug=false to "true"
now surf to state.aspx.
You should see the error description now.
Have done that and now do I get:
System.Exception: This page has a MM:DataSet, MM:Insert, MM:Update or MM:Delete tag with a null or empty value for the DatabaseType attribute.
Often, such values come from application settings in the web.config file. That file might be missing from the server executing this page. Or, it might be missing the particular add key tags for the database connection this page uses. If you are using Dreamweaver, look for the web.config file in the local root folder of your Dreamweaver site. Once you find this file, you can either:
Put this file onto the server that is executing this page.
Copy the add key tags from the web.config in the local root folder of your Dreamweaver site and paste them into the web.config file in the server that is executing this page.
and my web.config looks like this: (Datasource/user ID and Password have been replaced by xxxxxx)
<configuration>
<appSettings>
<add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm" />
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=xxxxxx\sqlexpress;Initial Catalog=Lansweeper;User ID=xxxxxx;Password=xxxxxx" />
<add key="MM_CONNECTION_SCHEMA_Lansweeper" value="" />
<add key="MM_CONNECTION_CATALOG_Lansweeper" value="" />
<add key="dateformat" value="dd/MM/yyyy" />
</appSettings>
<system.web>
<compilation debug="true" strict="false" explicit="true">
<assemblies>
<add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
</assemblies>
</compilation>
<httpHandlers>
<remove verb="*" path="*.asmx"/>
<add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false"/>
<add verb="*" path="*_AppService.axd" validate="false" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
<add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
</httpHandlers>
<httpModules>
<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
</httpModules>
</system.web>
</configuration>
