sathish
This is something astonishing application for IT professionals and administrators.
I recently downloaded this application and installed in my network with SQL 2005 express edtn. Before deploying i read the docs and done. But installed in Windows XP w SP3 PC, it works fine and the report generated only for the particular PC where the service running.
I tried to deploy the LSclient.exe through GPO, in that PC while rebooting that login script it will run and the status in the command prompt screen shows connecting... for a min and immediately it disappear and i couldn't able to go further and no where else the process is running.
If any suggestions available would be highly appreciated.
Thanks in Advance. Looking forward for your reply.
Best Regards,
Sathish Kumar
13 REPLIES 13
Should be:
Set WshShell = CreateObject(WScript.Shell)
WshShell.run "\\matrix\netlogon\LSclient.exe orion", 0
sathish
Here you Go...
WshShell.run matrix\netlogon\LSclient.exe orion, 0
Could you post your script here please
sathish
FYI...
Here is the error "Expected End of Statement"
It appears in Windows Host Script
sathish
where i have to execute the command?? try to understand the issue here.
Installed the Lansweeper server service in Windows XP Pro W sp3 (the reason here i installed in XP is i do not want to test this in live environment) hence installed and planning to upgrade Premium version, but for standard version itseld i am not satisfy with the Support.
Thnx...
sathish
it shows only connecting.... after that it disappear,
there is no failed or success, i couldn't able to see
First start the commandprompt with cmd.exe
The start lsclient (you should see the result now)
sathish
once i reboot the PC and logged with administrator, that script will run shows connecting.
However the startup.cmd is there in my AD server, my query here is it has to run, right....
Does it show : failed or success?
