sathish
This is something astonishing application for IT professionals and administrators.
I recently downloaded this application and installed in my network with SQL 2005 express edtn. Before deploying i read the docs and done. But installed in Windows XP w SP3 PC, it works fine and the report generated only for the particular PC where the service running.
I tried to deploy the LSclient.exe through GPO, in that PC while rebooting that login script it will run and the status in the command prompt screen shows connecting... for a min and immediately it disappear and i couldn't able to go further and no where else the process is running.
If any suggestions available would be highly appreciated.
Thanks in Advance. Looking forward for your reply.
Best Regards,
Sathish Kumar
13 REPLIES 13
What was the output of step 2?
sathish
i tried those options, but no luck...
i hope somewhere something is wrong...
1) make sure that your service is running.
2) Start lsclient on a computer manually from the command prompt. (so you can see the result)
3) Review the errorlog.txt file in the service folder on the server.
taeratrin
The client is only suppose to run for a couple of seconds. All it does is tell the server "I'm here. Scan me."
It is also best to put it into the user's login script, as opposed to the boot script. This way, you can keep accurate track of which computer each user is logged into.
