joachimcarrein
I just installed version 3.5 and had no errors during install.
The webservice is available (without any systems in it yet).
But the lansweeper server is not started. When i try to start it, i receive following message:
Services
The Lansweeper Server service on Local Computer started and then stopped. Some services stop automatically if they have no work to do, for example, the Performance Logs and Alerts service.
OK
I do not find an errorlog in the service folder or in the event viewer.
This is my install log:
24/03/2009 16:14:49 - ------------ Lansweeper Setup Started ------------
24/03/2009 16:14:49 - OS: Microsoft Windows Server 2003 Service Pack 2 (Build 3790)
24/03/2009 16:14:49 - Inst: 3.5.6
24/03/2009 16:22:05 - Checking connection to SQL ...
24/03/2009 16:22:07 - Connection to SQL ... succeeded!
24/03/2009 16:22:09 - Checking rights for user: domain\administrator ...
24/03/2009 16:22:09 - Checking rights for user: domain\administrator ... succeeded!
24/03/2009 16:22:21 - Checking user account needed for service setup ..
24/03/2009 16:22:21 - UserName / Password are OK!
24/03/2009 16:25:15 - ------------ Running Preinstall tasks ------------
24/03/2009 16:25:15 - Removing older Lansweeper service, if exists...
24/03/2009 16:25:15 - Removing Lansweeper database, if exists...
24/03/2009 16:25:15 - Dropping Lansweeper Database... done.
24/03/2009 16:25:15 - ------------ Installing Lansweeper Files ------------
24/03/2009 16:25:15 - Operating System: Microsoft Windows Server 2003 Service Pack 2 (Build 3790)
24/03/2009 16:25:15 - Database Server: SQL Server 2005 Standard Edition SP2 ver. 9.00.3077.00
24/03/2009 16:25:23 - ------------ Running Postinstall tasks ------------
24/03/2009 16:25:23 - ------------ Installing Lansweeper Database ------------
24/03/2009 16:25:23 - Creating Lansweeper Database...
24/03/2009 16:25:24 - Creating Lansweeper Database... done.
24/03/2009 16:25:24 - Building Lansweeper Database Objects...
24/03/2009 16:25:26 - Building Lansweeper Database Objects... done.
24/03/2009 16:25:26 - Populating Lansweeper Database...
24/03/2009 16:25:26 - Populating Lansweeper Database... done.
24/03/2009 16:25:26 - Create login lansweeperuser...
24/03/2009 16:25:27 - Create login lansweeperuser... done.
24/03/2009 16:25:27 - Grant DB access to lansweeperuser...
24/03/2009 16:25:27 - Grant DB access to lansweeperuser... done.
24/03/2009 16:25:27 - Add rolemember to lansweeperuser...
24/03/2009 16:25:27 - Add rolemember to lansweeperuser... done.
24/03/2009 16:25:27 - ------------ Installing Lansweeper Service ------------
24/03/2009 16:25:27 - Configuring Windows Firewall...
24/03/2009 16:25:29 - Creating Lansweeper service configuration file ...
24/03/2009 16:25:29 - Installing Lansweeper service ...
24/03/2009 16:25:30 - Lansweeper service installation completed successfully.
24/03/2009 16:25:30 - Starting Lansweeper service ...
24/03/2009 16:25:44 - Lansweeper service started successfully.
24/03/2009 16:25:44 - ------------ Configuring Lansweeper WebConsole ------------
24/03/2009 16:25:44 - Configuring Internet Information Services ...
24/03/2009 16:27:02 - Checking the root site ...
24/03/2009 16:27:02 - Connecting to root site ...
24/03/2009 16:27:02 - Removing old virtual dir, if exists ...
24/03/2009 16:27:02 - Creating Lansweeper website as virtual directory ...
24/03/2009 16:27:02 - Setting default values for website ...
24/03/2009 16:27:02 - Creating website config file ...
24/03/2009 16:27:06 - ------------ Lansweeper Setup Finished ------------
am i missing some settings or did i do something wrong?
joachimcarrein
it did not present any warnings.
Joachim,
Did the installer warned you when you entered the username/password?
joachimcarrein
i changed the login of the service to the actual domain administrator, this seems to work. Strange thing, since the user i used before was in an systemaccounts group, that is in turn in the domain admins group...
joachimcarrein
I just changed the user rights to the lansweeper install folder and now i see following information in the errorlog
24/03/2009 17:23:02: Database connection successful, starting up service
24/03/2009 17:23:02: Access is denied
at System.Net.HttpListener.AddAll()
at System.Net.HttpListener.Start()
at LansweeperService.Listen.DoListen()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Then the service stops again
