clmowers
Hello, I Install the new 3.0 and it looks great. Alot more stuff then the old one. My only problem is this. I have all the software install correctly and running. Its gathering info and showing the info. but when I click on a computer i get this error.This is only towards the bottom of the screen. the rest of the info shows Does anyone know what wrong
System.Data.SqlClient.SqlException: Invalid column name 'computer'.
at DreamweaverCtrls.DataSet.DoInit() System.Data.SqlClient.SqlException: Invalid column name 'computer'.
at DreamweaverCtrls.DataSet.DoInit()System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()System.Data.SqlClient.SqlException: Invalid column name 'computer'.
11 REPLIES 11
clmowers
Its with the final release, How do you attach files in the forum. I dont see an attach button
Did you get this error with the beta version, or the final release?
Could you post a screenshot of the error please.
