mbonal
I just upgraded from 3.2 to 3.5 and now I am getting this error in the error log. This has never happened before and I am wodnering what changed to cause this? It is causing alot of trouble.
8 REPLIES 8
mbonal
Have you all figure out anything?
There are two domains..
an NT 4.0 domain and a windows 2003 domain!!!
I do not understand why this all worked last week prior to the upgrade!
mbonal
I forgot to add the rest here.
(Exception from HRESULT: 0x8007054B)
mbonal
I attached the file
Click the attach button after you made the post (on the right of the screen)
Just for the record: only windows 2000 or higher is supported.
mbonal
I have the account from my NT 4.0 domain domain admin account still active on the services account and I have a two way trust between the two domains while I migrate to active directory. This all worked before the upgrade so something changed in the code.
How do you attach files?
mbonal
I have looked at the other thread and that has solved nothing. The account used on the service account is a domain admin account adn was used and worked before. I tried a different domain admin account and same result. Something isnt right in the code somewhere.
This is indeed a different error that you are getting.
Please provide following information:
With which account is the service running. (should be able to read domaincontrollers in the target domain)
Post a screenshot of the domain you filled in into the active scanning field.
See this thread : http://www.lansweeper.com/forum/yaf_postst1296p2_Lansweeper-not-working-after-32-to-35-update.aspx
Could you post the exact error please.
