StephenL
Is there anyway to get the vnc client to save your connection settings as default?
because each time i need to change my screen scaling down to 90%
is there also anyway in getting the vnc service to instance to stay on the client? instead of removing after use for quicker connection next use?
This particular setting cannot currently be saved. (The settings you see when launching the lsremote.exe directly and hitting the Options button are saved.)
This is not currently possible. VNC is always removed after the Remote Control session.
