jgabriel
Since version
5.2.0.31, when we visualize the asset's comments, the comments column width is too small.
I request that this column widths keep previous versions, or is resized according to the size of the browser.
tested with Internet Explorer version 9 and above.
very extensive comments are dashed in endless lines due to the small width of this column.
thank you very much.
Yes, the fix was included in 5.2.0.33, which is available on the website. Bert must not have noticed this. Update instructions can be found here.
sweept
Erm... what about upgrading to v5.2.0.33? Changelog:
Fixed: Comments Column width cosmetic issue.
jgabriel
thanks , hope the new version .
Bert_D
There is already a testing version that has a fix for this problem.
If you can't wait for the official release contact support@lansweeper.com for a link.
