‎09-05-2022 10:24 AM
Hello
I juste configured some Dynamic Groups, and i asked myself, if it is possible to add more Colums like for example Purchased Date or Last User, or every other Colums that is shown on the All Assets Overw
Solved! Go to Solution.
‎09-05-2022 10:42 AM
Hello there!
Unfortunately, at this time the filters are limited to the fields that you see in the screenshot below plus all 20 custom fields. So it's currently not possible to use the built-in field Purchased Date. As a workaround, you could manually copy this data to a custom field which can be used as a filter, but this would require some manual upkeep.
‎09-05-2022 11:22 AM
Thanks for clarifying!
None of these built-in views can be customized, unfortunately. However, this could be achieved by creating a custom report that displays the data that you require.
When creating a custom report, you can make use of our database dictionary, which explains in great detail what each database table and field stores. More information on the dictionary can be found here: https://www.lansweeper.com/knowledgebase/accessing-the-lansweeper-database-documentation/
Hello there!
‎09-05-2022 11:15 AM
