jstevens5591
I know how to add a host header to a website within IIS, but I am wondering if there is anything special I need to do within Lansweeper to make the Web Console have a more friendly URL instead of the standard http://SERVERNAME:Port
Daniel_B
This is the URL of the computer hosting the website. You could either change the hostname of your Lansweeper server or set up IIS with HTTP redirection on a host with a more friendly name. In order to use the standard port, change the port binding and use port 80 instead of your current port number.
WuGe
A DNS alias would also be possible instead of changing the hostname of the server.
Daniel_B
Is there any information you can provide for naming the host and setting the port for the classic installation that is using IIS Express?  Can you provide a link to the Lan Sweeper instructions document, not Microsoft's IIS instructions?
Katgroup
Setting up a URL redirect in IIS is outside the scope of Lansweeper. You can change the port by reinstalling the Lansweeper web console.
