paprita
I have to permanently delete some machines ... I'll try to delete them but they are always there ... what could be the problem?
Please contact us by e-mail lansweeper@hemoco.com so we can create a customised lsmanage.exe with large time-out values.
33 REPLIES 33
TsysDonotscan
paprita
Lansweeper wrote:
TsysDonotscan
You can go directly in the database with msaccess and copy paste the pcnames (from excel) into the table.
paprita
I guess I have to copy computer names from tblcomputer but in which table I have to paste them? ... just not to make some mistake ... ;-)))
paprita
After all, as preview by you, PC permanently deleted from DB, reappears.
Now I'll put them into "Not to scan" zone but I think that this function should be correct.
Indeed, if you put them into the "not scan" table they will be ignored.
paprita
Ok, all it's clear ... because of the great number of PC to set as "not to scan", in order not to take hours for this operation, is there a way to go directly on DB and set some flags or something similar?
paprita
Going back to the first problem, I'd like to use the normal function (and not the script) because I need to permanently delete more than 500 PC: how can I do?
