‎08-31-2009 06:15 PM
Solved! Go to Solution.
‎09-08-2009 09:54 PM
‎09-17-2009 05:30 PM
‎09-17-2009 05:32 PM
Lansweeper wrote:
TsysDonotscan
‎09-17-2009 05:07 PM
‎09-17-2009 05:20 PM
Lansweeper wrote:
You can go directly in the database with msaccess and copy paste the pcnames (from excel) into the table.
‎09-16-2009 01:13 PM
‎09-16-2009 01:16 PM
paprita wrote:
After all, as preview by you, PC permanently deleted from DB, reappears.
Now I'll put them into "Not to scan" zone but I think that this function should be correct.
‎09-17-2009 01:39 PM
Indeed, if you put them into the "not scan" table they will be ignored.
‎09-07-2009 04:36 PM
