Deployments can be executed in one of the following modes:
- under Scanning credentials (the credential which is valid for scanning the target computer will be used to execute the deployment scripts)
- under the System account
- as the currently logged on user (this is required if there is any user interface in your deployment package)
If you are using files from your package share, the credential which you entered under
Deployment\Security options will be used to access these.
Details on how to deploy a package can be found in
this KB article.
