mkhalil
Our team of engineers are administrators on their laptops so as to allow them to use the older version of OpenVPN (2.3.9) The latest version of OpenVPN (2.4) allows for users to connect (without the need for them to be admins to their machines) and we are trying to push out the updates using Lansweeper's Deployment option but without success.
I have used the installer option and also tried to install the latest version of OpenVPN using the CMD command but could not get it to work.
Can anyone offer some help with this issue?
Bruce_B
The exact parameters and commands required for a remote unattended silent install of OpenVPN are not known to us unfortunately. These parameters and commands vary between different software installation executables and are decided by the software creator in most cases. Most vendors supply remote installation instructions for their product though.
While testing your command steps though, you can test them in the CMD on a target computer, any command that works in the CMD should work in the deployment module.
Bruce_B
