11-13-2024 02:52 PM
We get:
If i press ok we get
I'm running the installer as AdminRunning SQL server 2022 LocalDB
Lansweeper is functioning normaly
Any idea what's going on?
Solved! Go to Solution.
11-14-2024 01:17 PM
Hello Somelsadmin,We've seen a few similar cases and we hope to solve this in a future release. As a workaround you can install both the x86 and X64 versions of the MS VC redistributable from: https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170#visual-studio...This should solve it normally.
4 weeks ago
I am getting the same error and was able to continue to installation. Do I need MS VS? Based on the installation continuing, no, but I wanted to double check.
