Roofus_143
Is it possible to exclude a single IP, or many IPs from a scan range, such as 10.0.0.x/24?
MakeBug
If you go to "Scanning Targets" you have the point "scanning exclusions".
There you can select "Add Exclusion" and enter the IP.
However I have no idea if it really works
fjca
You need a "wildcard/mask"-type exclusion, and I don't think that is supported...
My option would be to do an Excel CSV file with all the 140 VLANs', but with the last octet being .239
Something like :
10.33.0.0-10.33.0.239
10.33.1.0-10.33.1.239
10.33.140.0-10.33.140.239
And import that via Import Template.
uke-afu
Anybody knows?
Something like :
I will try it with the Import-Template, but a clean solution looks different 🙂
Cheers
Andre
uke-afu
I 've tried this, but it won't work.
We scan the Network for this IP Range:
10.33.0.0-10.33.140.254
What we want:
In every Subnet exclude .240 to .254
Tried this Exclusions:
0.0.0.240-0.0.0.254
10.0.0.240
10.0.0.254
10.33.0.240-10.33.0.254
WHERE IS THE PROBLEM/MISTAKE?!
Thanks for advise 😉
Andrew
Roofus_143
That works, thank you!
MakeBug
