BigFish7
Currently we have assets with LSAgent on them that are also in the IP range for network scans. Is there anyway to exclude workstations with the agent installed from these scans?
Other assets in those ranges might not be able to run the agent or the install failed for whatever reason, so I'd still like them to be covered.
Mister_Nobody
Honored Sweeper III
Did you use last version?
There is option on lsagent page to ignore another scans
Mister_Nobody
Honored Sweeper III
