07-20-2023 05:27 PM - last edited on 04-02-2024 11:10 AM by Mercedes_O
Hello Sweepers,
I've recently been assigned as the official "Lansweeper guy" for my company, not an actual Sysadmin and most of my experience with LS is adding and editing assets as states change (assigning to AD objects, changing states, e-waste, etc). I also have experience with running scans (web version of LS). Currently we are looking to "restart" fresh with Lansweeper and there are some concerns that need to be addressed or resolved:
There are other issues and concerns, but these are the top 3 as of right now. Being "new" to the inner workings of Lansweeper I definitely don't have the answers or tech experience with the backend of LS to answer these questions or resolve these issues. The video section is informative, but is showing off of a different UI than what we are using (web 10.2.5.0).
Thank you for any help, direction, or insight anyone has on this.
Solved! Go to Solution.
07-21-2023 03:09 PM
1. You can most certainly export a list of your current assets. Just go to you assets view, and select Export to Excel, or what ever choice you would like on the left. When you re-import - you only add the basics of information, such as serial number, make/model, mac address. The deep down stuff is only added during a scan (software, history, hardware info).
2. LSAgent, It should not duplicate itself, just make sure you select "Merge windows computers based on serial number and model only (not MAC address). located under configuration - server options.
3. As for Halo ITSM, hopefully someone else has experience with it. Main thing is make sure you have all the settings correct.
07-21-2023 10:17 AM
Welcome to the Community 'official lansweeper guy'😀, @rader @Hendrik_VE @Mister_Nobody @duster1 might have some insights
