getuliodesousa
I am having trouble setting up and using Deployment. I followed these instructions:
https://community.lansweeper.com/t5/deploying-software-other-changes/create-a-deployment-package/ta-...
https://www.youtube.com/watch?v=qLBebVbUcIc
I tried to install 7Zip but I am getting this error
Log DateAssetnamePackageExecutorReturnLast StepRun ModeMessage
17/02/2025 18:32FSF-TI00Instalação 7ZipGetúlio de Sousa - T.I-12Scanning CredentialsResult: Package timeout reached. Stopping deployment executable: Successful. Timeout: (900sec). Credential: (saofrancisco\ti). ShareCredential: (saofrancisco\ti).
I am using these parameters for the installation
https://prnt.sc/TCZrIiQMeofv
I have verified that the process is running on the target machine but it does not complete.
Screenshot por Lightshot
GET STARTED TODAY ► https://goo.gl/5q9VP1 Learn how to deploy software in Lansweeper 5.2 USEFUL LINKS Website ► http://www.lansweeper.com/ Latest installer ► http://www.lansweeper.com/Download.aspx Knowledge base ► http://www.lansweeper.com/kb/ Forum ► http://www.lansweeper.com/forum/ CONNECT WITH
getuliodesousa
Hi there,
Now I tried to install using the .msi, but without success and I forgot to mention that I have AD in my environment.
Log DateAssetNamePackageExecutorReturnLast StepRun ModeMessageDeployer Version
20/02/2025 21:21VM-BONZAYInstalação 7ZipGetúlio de Sousa - T.I-12Scanning CredentialsResult: Package timeout reached. Stopping deployment executable: Successful. Timeout: (900sec). Credential: (saofrancisco\ti). ShareCredential: (saofrancisco\ti).9.2.0.1
20/02/2025 16:21VM-BONZAYInstalação 7ZipGetúlio de Sousa - T.I-12Scanning CredentialsResult: Package timeout reached. Stopping deployment executable: Successful. Timeout: (2700sec). Credential: (saofrancisco\ti). ShareCredential: (saofrancisco\ti).9.2.0.1
These are my settings and I have also created a GPO to open port 135, set the Task Scheduler and Remote Registry services to run and also enable Remote Scheduled Tasks Management in the Windows firewall.
These are the settings I have made.
Hm.  ThoKI's reply shows that indeed an .exe can work with this deployment (a lot don't)...  but, the error is a timeout so that most likely means that it's not getting the result sent back to the server (error, success).  What version of Lansweeper are you using?  Do other deployment packages work?  Also, you can try out the nifty device tester tool on your scan server:
I'm using version 12.3.2.3, I tried to install notepad++ but it was .exe, I couldn't find .msi for testing, and without success.
21/02/2025 12:02VM-BONZAYInstalação - Notepad++Getúlio de Sousa - T.I-12Scanning CredentialsResult: Package timeout reached. Stopping deployment executable: Successful. Timeout: (900sec). Credential: (saofrancisco\ti). ShareCredential: (saofrancisco\ti).9.2.0.1
I tested the application you mentioned, here is a printout.
ThoKl
here is my perfectly working 7z setup deployment package. I have it running as System account.
Jacob_H
Hey getuliodesousa:  The 'Installer' step type is really for .MSI packages - .exe wrappers generally don't work with that - you generally have to make a .bat file or otherwise run a command.  I would suggest downloading the .MSI instead of the .EXE.
https://www.7-zip.org/a/7z2409-x64.msi
