jabe
In my Lansweeper installation, the "Actions" button in the Helpdesk is not showing.
The licence is correct and my User is set as Admin + Agent (and the user is made Agent in the general settings).
I'm not able to assign Tickets or change states.
Any ideas?
jabe
Solution:
The Windows-Group, which controls Lansweeper access in our domain, had to be inserted in the user configuration.
jabe
Solution:
jabe
Update:
If i change the User to be a user, not an agent, the "Actions" button appears.
But i have to be able to be an agent and assign tickets to myself or, in case that my user is also supportadmin, assign tickets to other agents.
David_GF
hi @jabe
Could you check the permissions assigned to the role? You can find them under Configuration > User Access & Roles. The screenshot below is the default settings for Administrator + Agent role:
Sweep that LAN, sweep it!
jabe
hi david,
i have set all permissions (even the delet tickets and edit other agents notes).
i have use a new user to test the configuration, too.
The "Actions" button does not appear.
