Showing results forĀ
Did you mean:Ā
Will
I am hoping to be able to list assets connected to access points like you can switches. Under the "network interfaces" section on a switch, it lists each known LS asset as well as other MACs that aren't in LS, with a hyperlink to those known assets. Is there a way to do this with APs? We are using Cisco Meraki if it matters, and the SNMP values are already set on the switches and APs.
Ideally, we would be able to click on an asset and see what AP it was connected to at its scanned time. It would help with troubleshooting without having to go into Meraki and (hope) that we can identify the asset in there.
Thanks!
Pics for reference (this particular one has a non-Meraki switch, but the experience is the same on either):
jarias479
I need the same
ErikT
Hi there,
Unfortunately, Lansweeper currently does not have this option.
We've added this feature to our customer wish list as a feature request.
Feature requests are prioritized based on customer demand and implementation weight.
Currently, we cannot guarantee this will be implemented nor can we provide an expected release date.
how can i push/rate this wish? I have the same request
