mkergan
Is there a list of authorized parameters when installing a program? ie, silent install, eula. I want to install programs, without interrupting the user or have the screen show that there is a program being installed.
Florian_Eigsi
You should find usefull tips for silent install software
https://wpkg.org/Category:Silent_Installers
First thing is try to test exe with /? parameters
PeterJG
each installation packager has different sets.. msi are very common however EXE setups might varry... i use
https://www.softpedia.com/get/System/Launchers-Shutdown-Tools/Universal-Silent-Switch-Finder.shtml
universal switch finder to help out tremendously.
