danielideho
We currently have a Lansweeper On-Prem installation, and in the past we’ve tested the Network Discovery Hub as well. We noticed that the Hub’s Asset Radar could detect more than the on-prem server — especially things like phone connections, IoT devices, and other ‘non-traditional’ endpoints on the network.
Now we’re wondering:
Is there any way to enable similar Asset Radar detection on our On-Prem server?
  • For example, is there a way for the On-Prem scanner to see phone connections the same way the Hub’s Asset Radar does?
  • Are there extra configurations or agents we can deploy to extend the On-Prem scan to mobile or IoT devices?
Or is this a capability unique to the Network Discovery Hub, meaning we’d need to run both the On-Prem server and the Hub in parallel to get full coverage?
Obi_1_Cinobi
Hello there!
Before confirming this, we would like a deeper technical review of these phone connections to understand why asset radar (on-prem) isn't detecting them. This might be a configuration issue or a feature request. Can you open a support case so we can investigate?
https://www.lansweeper.com/contact/contact-support/
If you have trouble accessing the Support Portal, please use this URL instead: https://www.lansweeper.com/contact/contact-support-case/
